#14166 05/14/15 04:45 PM
Up then down
Up then down
One of techs found Kone KCM 831 emerg phone re-dialing over and over and over. 831 really doesn't have a "phone" -- phone is Kone board and on a RIF board in the car top. Reset or power down does not reset.
Any suggestions before I order another RIF board (very pricey). This our only diagnosis -- bad RIF phone board / stuck relay on board, etc.
We unhooked from button -- still redials
Monte Ball #14171 05/14/15 08:57 PM
BRG Offline
Open some place in the circuit.
BRG #14174 05/15/15 12:45 AM
I believe they will run without the RIF. Have you tried to remove it?
john jay #14175 05/15/15 01:36 AM
We have in the past just replaced the on board phone for a local direct dial phone. power down the existing unit, and then use the existing phone line.
uppo72 #14182 05/15/15 07:55 PM
The elevator will run without the RIF. Don't spend your money on that board. You won't even be able to program the phone number in unless you go through KONE. Unplug the communication connector that goes to COP and plug it directly into Car top board. Order a wurtec phone.
jdog #14184 05/15/15 07:57 PM
I agree with going with another phone. However, you can reprogram the existing phones without going through Kone. I have the write up if you need it.
solidstate #14187 05/16/15 11:46 AM
BRG Offline
One other thing that I know from years of adjusting. If the person does not properly end the call from the phone, it will redial. They need to hit the "3" key then the "#" key. Not too fast because the system is rather slow.
BRG #14188 05/16/15 04:17 PM
solidstate<< Can I get a copy of the writeup to reprogram it?
Alex75 #14190 05/16/15 09:29 PM
I would like to get that write up also. I have a number of these phones.
solidstate #17768 08/18/16 01:20 PM
Any chance you still have the write up on phone reprogramming?
Monte Ball #17771 08/18/16 04:48 PM
Unplug white nylon Molex going into RIF board for a few seconds then plug it back in to reset.
Unplug the phone plug going into RIF and connect to a handset then see if it dials in and out. If all is well you have a bad RIF board.
koneisland #17775 08/18/16 07:09 PM
Put me on the list for that write up please!
danzeitz #17776 08/18/16 09:40 PM
Charles, pm me or post your email.
Dan, it is in your inbox.
solidstate #22540 12/19/17 06:57 PM
Do you still have the programming instructions? I would greatly appreciate a copy. Thanks!
solidstate #37992 08/15/24 05:51 PM
Could you send me write up please?
Monte Ball #38189 09/09/24 12:04 PM
mightyo68
mightyo68
I would greatly appreciate those programming instructions too. Could you send it, please?
PHP: 8.3.36 Page Time: 0.028s Queries: 46 (0.010s) Memory: 3.0699 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-05 22:17:37 UTC
