Doug
Doug
Been working on an old Reliable Elevator 8 stop traction car and it wont kick into high speed and is barely moving at a slow speed. Moves at a really slow speed on inspection. Swapped out all relays and still nothing. Checked all the capacitors also. Anyone have any ideas? My next step is to pull motor
is the H relay picking up for hi speed? are all the P, PP, PPP SR relays energized?
what kind of drive unit does it have? probably an SSD-1 or GFC box, could be a bad box. check your generator field voltage, should get around 80-100 volts across the generator field to give 200-240 volts output at the generator. if you are getting low generator field voltage, its either a bad box, or connection, resistor bad contact on P, PP SR etc. also have you checked the generator field fuse on the ssd unit.
i would not think about pulling the motor until you can verify that you can control the generator output with varying generator field input.
pm me with your email, i have some info on the reliable elevators, and the SSD drive unit that you may want.
I have to say...its not THAT Reliable then is it...LOL
PHP: 8.3.33 Page Time: 0.029s Queries: 20 (0.005s) Memory: 3.0045 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-21 04:32:03 UTC
