#14419 06/11/15 08:15 AM
O
O Offline
I am hoping that someone can assist me with a problem with initial start up. Gen 2 not regen drive. Mcb 3. The initial calibration procedure, we get a learn abort encoder error. However we cannot find any reason. Encoder has been swapped, Mcb 3 swapped, drive swapped. Brake removed from motor to make sure no interference.
Motor moves slightly, couple of attempts, another message that comes up, SYS message lost.
anything please.
J Online: Content
don't know if this is relevant, had a similar problem on a Montgomery with a Baldor Drive. Had to change the number of Motor Windings from 4 to 6 in the Motor Parameters.
The "Sys: Message lost" normaly generates some errors in the event log? Have you checked the encoder parameters under Setup/Contract?
Maybe try to default the eeprom and re enter the parameters?
make sure car is running in the right direction..did you have a bad encoder and just installed a new one on a running unit?
O
O Offline
Bad harness? check for 3v on each channel.
PHP: 8.3.36 Page Time: 0.028s Queries: 24 (0.009s) Memory: 3.0161 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-04 20:02:36 UTC
