Posts: 52 |
Looking to get feedback on Thyssen Krupp Northern elev TC3200 controller and how it is to deal with them in general. Thanks
Posts: 23 |
I believe you'll need the MAP tool on the Northerns. The units I took care of had ECI DOOR equipment, controller wise they are OK. I remember replacing a selector, and a load weighing board on the car top. But I remember having to send back the MAP tool to thyssen, because it is only good for so many plug ins.
Posts: 736 |
I thought World Electronics made a MAP Tool for sale.
Posts: 37 |
I take care of a lot of these if you need any help pm me.
Posts: 4 |
Good day, having issue with the Tc 3200. It'll run fine on automatic after a few runs, It takes itself out of service. If I hit main reset it will run a few more times and then shut down
Posts: 17 |
could be a few things... odds are its the HVS-9603 Board. Most of the time thats the thing that fails.
(probably need to send it out for repair and refurbishment. the power supplies and capacitors sometimes goes.)
Posts: 579 Likes: 6
Posts: 579 Likes: 6 |
Whats the deal with these? Around here I've only ever seen tac 50-04s. Are these an old controller or one TK uses in markets outside the USA?
Posts: 224 Likes: 4
Posts: 224 Likes: 4 |
Thyssen themselves didn't actually buy US Elevator. It was their Canadian subsidiary Northern that actually bought them in 1994. The Northern design is based on US Elevator with only 2% difference. Northern sold a revised version of the US product until 1999. Northern continues to make their own product line, independent from the one based on thyssen's other predecessor, Miami Elevator, but now operates under the TK Elevator Canada branding (after ThyssenKrupp became TKE).
PS: This is no opinion. Northern is the best elevator company ever. It's the only brand of elevator I've never been stuck in and never had trouble with. The total number of Northern's I've used was over 132, not just 1 or 2. It's also the only brand of elevator I've never seen break down before.
Posts: 579 Likes: 6
Thanks. That explains alot
Posts: 318 |
Has anyone ever replaced the Thyssen Krupp Quantum Quiet Drive on these controllers with something else before? There is a tender out that only wants the drive replaced but to retain the 3200 controllers.
Posts: 224 Likes: 4
It should be a moral sin to replace a 3200. Northern is the best company ever. It's the one and only brand of elevator I've never been stuck in, never had a problem with, never seen break down, and never almost got injured on. At least Northern had since enough to use ECI and Wittur (later on) for door operators instead of GAL like the little companies, which came with the own door panel design with study feet (gibs) as opposed to that horrible EPCO and Nylube crap used by the little companies, and better yet, poly door rollers as opposed to those crappy noisy nylon duds from GAL, with the felt wipers.
