#858 11/29/10 09:45 PM
Does anyone know the cab and hall button voltage on Mowery's equiptment. Its the srl stuff. They pulled the prints and most of there boards due to a builder going bankrupt and I would like to qoute it to get it back in operation. I found 2 transformers in what was left of the controller, 1 HAD A SECONDARY VOLTAGE OF 18 AND THE OTHER WAS 8.5V. THANKS!
Give SRL a call at 1.800.810.3754. They will not sell you any thing for it, but will at least give you the voltage for it. We have a couple on service. I can get the voltage for you if they can not help you out.
Service Manager
Service Manager
mowery relay logic or solid state? if this is relay logic mowery then the voltage is 120vac which is powered thru term a and x3
if this is solid state mowery(emac or omiron c20) then the voltage is 24vdc which is powered thru term 4 and 5 hope this helps i see im a bit late
PHP: 8.3.36 Page Time: 0.155s Queries: 20 (0.091s) Memory: 3.0048 MB (Peak: 3.5926 MB) Data Comp: Off Server Time: 2026-11-05 08:38:02 UTC
