Hi Everyone,
I am having trouble with an older Montgomery Miprom. When you turn the power on.The elevator will run to the top floor and level in and no door operation but the pump keeps running. I am not dropping UA and Delta of course keeps the motor running. I have changed all the input and output boards. I have installed a new power supply and an interface board. I have also changed the software.The only board that hasn't been changed in the controller is the resistor board. The part number on this board is P-15833. Has anyone had a similar problem like this? Any and all comments are welcome. Thanks in advance.
Do you have prints?
In-line, wye delta, solid state?
What's keeping the pump running?
it is possible you have a bad up leveling unit. to check disconnect the umlu wire at the trminal on the relay board.
Boa Offline
It's probably in the relay board, either a stuck contact or shorting at the terminals. I've had a spider cause something similar. If you have prints use general troubleshooting procedures, don't overthink the problems those miproms are fairly easy if you don't overthink. If you need prints or manuals let me know, it may take me a while everything is still on paper.
Msd Offline
Hi, is your LRU input high for level up should be off is not in level up vane? Does computer know it's in the leveling Zone by have LEV high and SU and US2 low?
Ron,
Are you saying the car stops at floor level, the pump continues to run and the valve bypasses the oil back into the tank?
PHP: 8.3.33 Page Time: 0.019s Queries: 26 (0.004s) Memory: 3.0192 MB (Peak: 3.5922 MB) Data Comp: Off Server Time: 2026-09-21 04:44:04 UTC
