#14594 07/02/15 04:10 PM
4 armor controllers connected together with a single dispatcher car#2 is responding to the whole push button calls BUT CAR DOOR WONT OPEN.
The elevator works NORMAL with car station calls. Car door open and close properly.
The problem basically is with the WHOLE PUSH BUTTON CALLS. Already double check the DO1, DO2, DOL1 relay contacts. Dispatcher seems to be working well.
If anyone with an experience like this one, please share your info. Any help is welcome.
Mark26 #14596 07/02/15 06:05 PM
I had the same problem with a triplex fst2.
Somehow I turned off the doors in the controller blush
gfv444 #14600 07/02/15 08:09 PM
It has nothing to do with the HCC switch on the controller this is a different problem I already went thru all that. This should be something related with the landing system or the door open circuit because the dispatcher order the elevator to go where the push buttons are calling. THe problem is that the elevator DOES NOT OPEN THE DOOR. Any ideas are appreciated.
Mark26 #17043 05/13/16 01:33 PM
Check ur DO1,DO2 ,DEB, DE, relay contacts one of those contacts isn't making up correctly , if I remember correctly is contact 5 to 6 in DO1, but the work together so once u go true all of them u gonna get ur car door to work properly
Mark26 #17044 05/13/16 01:45 PM
Now here is my problem : equipment from 1970 -4 cars with a single dispatcher , car 1 , 2 , and 4 are working in a different way , they have to reach top or bottom floor to change direction , another words if u take the elev on the 5th fl trying to go down to the lobby , the car have to go all the way up to the top landing -does stop in the top floor but car door doesn't open stay there for 3 seconds and then goes down to answer ur call or any other one in the down direction hall or car station call, I don't have the prints is kind of hard to hit the problem cuz u need to check the cars operation after each adjustment and without prints is going blind !!😠😳 any ideas or experiences are welcome
Mark26 #17302 06/13/16 02:49 PM
Check with [email protected] for prints... If he doesnt have them try Electrodyne
PHP: 8.3.33 Page Time: 0.086s Queries: 26 (0.055s) Memory: 3.0195 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 06:46:36 UTC
