#14768 07/24/15 11:52 PM
Do these controllers shutdown after a certain amount of time or a certain amount of uses?
beaupeep #14769 07/25/15 01:22 AM
No, they have no fault log/fault memory.
ABE #14770 07/25/15 03:58 AM
I had one shutdown today and as soon as i entered the 4 digit access code it started working
beaupeep #14772 07/25/15 06:13 PM
Those EZ scans can also shut the car down if they have something go internally. But the car will run without it plugged in.
ABE #14777 07/27/15 02:13 AM
Yes they do have a mandatory maintenance shutdown feature that if it doesn't see. A map unit, or ezscan code entry it will shut down. The system is doors open at a random floor, and all systems seem to be in auto. Another symptom is the car pi will flicker but I've seen it on some and not others. The 181 runs the 3200 cpu board early model) and all of mine have the shutdowwn feature. Even late model 1600s have this feature
pdq1600 #14796 07/29/15 01:55 PM
Thats interesting, my company probably has over 50 of those units on service and I don't think we have ever run into that. I'm assuming then you could go ahead and shut off that feature via the ez-scan? I'll have to look for that the next time I have the manual open.
ABE #14797 07/29/15 03:30 PM
I have 6 older Northerns that do that, log in with the Map unit and you're running. I have a bunch of newer Northerns with the on board Map unit that don't shutdown after x amount of runs.
galaxy #14801 08/01/15 04:04 PM
Does the TC 3200 have this same shutdown feature? I have 3 of these piles that we are losing in a month and they have started acting up pretty bad. I don't know how to retrieve faults and the building usually resets the cars before I can arrive.
NewMech #14822 08/06/15 02:59 AM
from what ive been told by northern if it requires a map unit, ezscan or elevision computer it has the mandatory maintenance option. there are 2 ways you can get faults. if you have the rms board on the front on the 3200 board with the screen and it will only show you the most current fault. (ie irr low from ppu, dol not active, low chc, ect) and with the map unit or ezscan you can access the special features which will show you fault codes which you would have to call northern to translate.
pdq1600 #14823 08/06/15 03:04 AM
I lost 2 of these units to another company not long ago. my last visit I plugged my map unit in, entered the code and left. 5 months later we got a call to that building because both elevators were down and the other company couldn't get them going (no map unit) we walked up and plugged the map in and away they went. my calculation would have been between 80000 and 100000 runs between code entries.
PHP: 8.3.36 Page Time: 0.071s Queries: 34 (0.036s) Memory: 3.0437 MB (Peak: 3.5926 MB) Data Comp: Off Server Time: 2026-11-06 00:00:06 UTC
