So first off lemme say these units are a real pain, I assume since I didn't check time and date I'm probably being locked out of the system, (didn't realize there are multiple versions of the mcp, jerks) I'm trying to figure out how to reset a fatal error and menu 10/101_1 isn't doing it. If I am locked out how do I unlock the madness? But other than the persistent shutdown error I'm getting an unintended motion fault as well. Tried to do the reset process but obviously that didn't work. I'm slightly at a loss, any help would be great and or an actual list of all menus and sub menus that go with them would be spectacular! Also the switch on top of the rail, gov side, I think is a normally open switch but should it be made up, causing the elevator to stop if it isn't, or vise versa
Muchos gracias for reading all that if you did!!! 😎
