#14898 08/25/15 02:06 AM
Have a lift that momentarily doesn't accept calls and sits with doors open. Everytime we show up car is running. Customer isn't resetting. Changed main i/o board, and tone generator. Happens on all floors. Anyone ever seen this?
beaupeep #14899 08/25/15 02:28 AM
Shaking the Bush!!
Shaking the Bush!!
Could be the door open limit not making. Or door close limit not breaking.
Magic smoke #14900 08/25/15 11:32 AM
This would cause my calls not to latch?
beaupeep #14902 08/25/15 02:39 PM
Is the car stuck at a floor with a hall call lit? I would try the cop power supply and hall button interface board.
NewMech #14903 08/25/15 04:51 PM
Have you checked the photoeyes/door edge sensor? How about the door open button? Those Otis buttons are junk. The randomness leads me to think it could be one of these.
rac66 #14906 08/26/15 02:20 AM
Check or replace the power supply in the COP. You may have ripple on the DC outputs. There are 2 Caps on the power supply. They do decay. The caps are a voltage 2X circuit to supply the 30vdc. If the Caps are bad or decayed, when the line voltage drops the DC reacts violently. At least try replacing the Caps.
PHP: 8.3.36 Page Time: 0.029s Queries: 26 (0.009s) Memory: 3.0201 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-04 20:41:14 UTC
