#15735 12/30/15 11:38 PM
Mechanic/Supervisor
Mechanic/Supervisor
I have recently done several mods to a smartrise controller. Just have to say that I love the product. Its so easy to work on. they have great tech support. cut down to minimal wiring. Just an awesome controller.
CM1981 #15741 12/31/15 02:09 AM
I do have some of these and I have to agree. Pretty good little controllers.
I like how you can adjust individual floor stops. Sweet!
we just installed our first one and we are getting an odd nts fault once in a while and sometimes the floor levels are off , It is as if it was losing its count but it's not, the only thing I can think of is that is that it has a software glitch .
Any thoughts?
ubro96 #15777 01/04/16 03:19 AM
CM1981 says "They have great each support". Time to dial 'em up.
I do remember though on one of my units the crew that did the annual testing had to change the NTS speed values to set/check the OS valve. BUT...they failed to return and save the "normal" slowdown values which created trouble for me after they had left. Maybe something to look into.
Just a few thoughts as far as floor levels go; have you set them, saved them and then they've changed? Has the job got a new valve? Packing issues- i.e. tight? Both directions have changed? All floors change?
No it's a 6 floor overhead traction saved, reset floors levels , saved again , tech support is at a loss they don't seem to have any answers , the fact that it is a interminent problem is always a hard to find ,but since we did the first learn run there has been this glitch it's been running about 4 months now with no calls but if you check the faults that nts is always there happening at differnt intervals.The floor levels are not off much but any deviation is not acceptable with todays technolgy.
Sometimes when controller manufactures adapt there controls to be compliant in Ontario Canada with all the redunacies that is reqiured here we end up with some weird Crap happening
ubro96 #15779 01/04/16 04:27 AM
Ahhh...
Traction. Haven't seen the SR Traction, but I guess it's safe to ask, does the system use mechanical switches for all terminal slowdowns, or magnets? I ask only because some OEM's have had issues in the selector department due to small gaps between the magnet stack for NTS/ETS that the CPU sees as turning off/on at an inappropriate time and faults the car. Closing this gap corrects the problem. I've seen weak magnets on the 211, and the TAC20 cause intermittent trouble too in stepping or floor position.
You've no doubt already covered a good bit of ground on this issue.
Hope you get to the bottom of it sooner than later!
Elm hit it. Weak magnets are murder on all the TAC equipment that uses them. If the logs show any sort of pattern, try switching magnets around.
Silly #15781 01/04/16 04:09 PM
Mechanic/Supervisor
Mechanic/Supervisor
All of the SR that we have done have been overhead traction.. One was a 10 landing one was a 17. It was engineered with the IP8300 Selection system. however, the first selector was bad on the 10 landings and for about 2 weeks we were having position issues. replaced the selector and sent the other one back and it ran like a champ.. As far as floor levels go, it is my understanding that you have to adjust them in the up AND the down direction. I started at the top and adjusted and saved all the floor levels, then couldnt figure out why the heck they were off sometimes and not all the time.. it was when i was traveling up that they would be off because i had only adjusted in the down direction. SR tech support caught it while I was talking to them, I did them in the up dir. and no problems after that.
CM1981 #15792 01/05/16 06:54 PM
Now there's one outta your hair! Thanks for sharing results.
J-R Offline
Great controllers. On the hydro watch the Valve coil relays, thay are the main failure I've experienced.
J-R #15869 01/15/16 03:09 PM
You can switch those valve coil relays out for a solid state board.
In the US by default all switches are magnetic, except your final limits. Smartrise does offer the option of using physical switches for DZ, ETS/NTS, and normal's. You just have to specify this when placing the order
Honestly they are a bunch of garbage. Depending on use gearless, geared, or hydro a two stop hydro is about the only thing we've had success with. Problems leveling on gearless cars, terrible dispatching overlay, door circuit issues, pressure switch direction problems...
dre1383 #15926 01/22/16 03:13 PM
ubro96, if you're also getting A60 alarms on occasion, or even if you're not, you may want to try setting the 13-097 parameter from x00 to x04.
Thanks ernischnerd I'll check that parameter out what's it for
ubro96 #16072 02/05/16 02:39 PM
I believe it's the equivalent of raising the sample rate for the selector position feedback.
No not quite the parameter is used in the position calculation when you are at the bottom landing. The parameter will prevent the software from performing a secondary check and updating the position.
I love Smartrise too, the rest of time on the beach.
Jajajaja.
Love the controllers. I've installed several since they were released to the public. Hardly no trouble calls and easy install. Great tech support too. Wouldn't install anything else.
PHP: 8.3.33 Page Time: 0.030s Queries: 54 (0.010s) Memory: 3.0956 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-21 13:19:33 UTC
