0 members (), 78 guests, and 3 robots.
#16136 02/12/16 01:20 AM
Get Screwed
Haughton was pushing these things out the back door back in the late 50s early 60s. Going to school in Toledo so we had a tour of the plant. There was one large lathe that had a hole in the wall lined up with it. This was the lathe they used to turn the screw on.
Guess, not a bad idea until hole in the ground filled up with water, dead rats or hypo needles.
Jim,
You are a fountain of knowledge. I can always count on you bringing something interesting to the table!
jkh #16141 02/12/16 04:36 PM
Cool! Did they install a lot of them in that time period? I've seen screw drive on wheel chair lifts and stage lifts but never an actual elevator.
What happens if you loose a motor or belts while the car is in the pit? Was there a manual crank in the over head like the screw drive wheel chair lifts have? lol
ABE #17257 06/05/16 11:23 PM
it has the modern screw
Very unusual elevator. Does the screw go into a hole in the ground (like a hydraulic elevator)? Is this a residential or commercial elevator?
PHP: 8.3.36 Page Time: 0.059s Queries: 29 (0.036s) Memory: 3.0188 MB (Peak: 3.5922 MB) Data Comp: Off Server Time: 2026-11-06 19:55:53 UTC
