Get Screwed
Haughton was pushing these things out the back door back in the late 50s early 60s. Going to school in Toledo so we had a tour of the plant. There was one large lathe that had a hole in the wall lined up with it. This was the lathe they used to turn the screw on.
Guess, not a bad idea until hole in the ground filled up with water, dead rats or hypo needles.
Posts: 909 |
Jim, You are a fountain of knowledge. I can always count on you bringing something interesting to the table!
Posts: 338 |
Cool! Did they install a lot of them in that time period? I've seen screw drive on wheel chair lifts and stage lifts but never an actual elevator.
What happens if you loose a motor or belts while the car is in the pit? Was there a manual crank in the over head like the screw drive wheel chair lifts have? lol
Posts: 1 |
Posts: 20 |
Very unusual elevator. Does the screw go into a hole in the ground (like a hydraulic elevator)? Is this a residential or commercial elevator?
