Posts40,945
Posts: 239 |
I had a IGBT explode on a miconic a's drive yesterday. I can see that these igbt's have been replaced before on some of the other drives. Does a bad VEC board or a bad firing board on the drive cause this to happen. If not, when this happens is it probable that these boards were damaged by the exploding igbt.
Posts: 197 |
Schimdler recomendation is remplaces all at the same time white the Samll boards over the IGBT, when money is important we change in pair normaly use 2 per line we remplace entire line and test
jj5
jj5
Posts: 22 |
Had the same thing happen, a bad INT (firing) board is what caused it. Not too many of them out there with the INT board. Most of them use the V2V board.
Posts: 239 |
It's was a bad INT board. It has a locked up pulse driver on it.
Posts: 239 |
When an igbt explodes on this controller, Is there a possibility that the power surge created could corrupt the eprom on the VEC board.
