#16499 03/23/16 01:48 PM
Vtravis
Vtravis
Hello, I have a KCM831 with KDM on service. Having an issue with elevator intermittently going down on a 106 - 1064 subcode. The problem is intermittent but happening often. Seems to mainly be happening after a run. Anyone have any experience with this fault? Thanks in advance.
BRG Offline
I didn't see a 1064 subcode listed on the kdm error log. I will look into the other literature I have. Sure it's a kdm?
Vtravis
Vtravis
Yes it is a KDM. My book says movement risk during start or stop sequence. The only thing that I can come up with is a problem with the brake module, but I can't pinpoint anything.
Check the Brakes and make sure the center nut is loose enough to move the flat washer by hand.
Vtravis
Vtravis
Both brakes look good.
Hi,
You could try monitoring the output voltage from the brake unit to the pods under load, around 200vdc if I'm correct? The brake units do fail, but it usually a relay contact going HR easily fixed and not to expensive if you can do it yourself, I've done quite a few, it's worth a try, let us know how you get on.
Dave
I had this problem and changed the brake module board to fix it,could also check ur tach and encoder any little movement will bring up the fault
Vtravis
Vtravis
Thanks to everyone for the input. Actually had to replace the brake module board twice to get the problem taken care of. Guess we got a bad new board. Thanks again!
PHP: 8.3.36 Page Time: 0.027s Queries: 30 (0.009s) Memory: 3.0315 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-04 21:29:11 UTC
