robot. |
improving the trade
improving the trade
Posts: 26 |
I seem to be having an intermittent problem with the GS_P input. I am not able to find it in the prints. it seems to be tied to door, gate locks, and DCL contracts. thanks
Posts: 909 |
Is this the same car you ask about BP? If it is, sure sounds like a bad MLB...
Do you have a tool? Do you have a 2962 error code?
Shaking the Bush!!
Shaking the Bush!!
Posts: 69 |
That's the gate switch PAL input. It's one of the inputs that does the C-I/O check before each run. It's a buddy(Pal) input. It should show two inputs on the print. They go to different areas.
improving the trade
improving the trade
Posts: 26 |
car is running, I believe the problem was DCL contacts not opening. the fault was 2812. I just got my hands on a tool for the next problem.
thanks
