#1096 01/28/11 03:56 AM
i believe talking about close calls keep us all on our toes.
i was changing worn starter contacts on a job we just took on service. i locked out the main line and 110, tested and verified the power was off. as i had the starter apart in my hand i got shocked. come to find out someone added fire service operation and ran a circuit through an extra starter contact powered by a separate building feed.
assume everything hot!
GreenPants #1111 01/29/11 05:38 AM
Obviously you didnt check ALL the asociated terminals etc. to check if power was off!
Hey GP-I heard a very similar story at our last safety beatdown. Are you the fella by chance?
E311 #1117 01/29/11 05:08 PM
EDM-A/Pilot
EDM-A/Pilot
Did it happen to be old Otis? lol. I treat those things as always live.
-Matt
Matthew #1118 01/29/11 08:50 PM
"Safety beat down" I love it
I didn't turn in a formal close call for that one. And yes I should have checked all terminals not being familiar with the equipment. Just like turning the car lights off to change a generator brush. Live and learn. Surprisingly Rodriguez was in town for a couple of days and didn't hit any of us for an audit.
GreenPants #1122 01/30/11 05:40 PM
Hey GP, Don't know if your up north here or in the south part of California. I just heard an inspector was shocked up here accessing a car. Seems he was touching the door frame and turning the key. It sent him to the hospital. It seems the ground wires were floating/ not connected and somehow a wire was pinched causing ground to be electrofied. He was hit with 230v I was told!
halfpick #1124 01/30/11 06:39 PM
Yikes, I hope he is ok. That's the freaky stuff in our job that you would be hard pressed to protect yourself from. We had a repair crew set to a job to replace some Vic rubbers and as the helper climbed in the pit he had is hand on the jamb and pit ladder and got lit up. Found out the anchor holding the pit ladder to the wall was hitting a underground electrical pipe. Been that way for years and no one knew till he got bit.
GreenPants #1133 02/01/11 07:17 AM
Wrench
Wrench
Wow some scary stuff.
Just can't leave it alone!
Wrench #1135 02/01/11 11:36 PM
We had a local member pulling Westinghouse rack out he was at the lower end when rack came out of polychains he broke both legs n had bad muscle tears but he didn't loose his legs thank god.
PHP: 8.3.33 Page Time: 0.030s Queries: 32 (0.006s) Memory: 3.0351 MB (Peak: 3.5924 MB) Data Comp: Off Server Time: 2026-09-21 14:13:56 UTC
