1 members (sampler),
80
Posts: 318 |
Having issues where doors stop working in both the close and the open positions. Tried swapping door board 3 times and problem doesn't go away. Won't even learn the door run. Does the clc prevent this from happening or the door op board?
Posts: 648 Likes: 1
Posts: 648 Likes: 1 |
the door board is only going to do what the clc tells it to do. Will it work with the MDO and MCO?
Posts: 318 |
Posts: 22 |
On the door board you have 3 buttons mdo is the manual door open and manual door close mdc and then a reset button
Posts: 318 |
Can do a door scan but it won't allow me to save pulse count parameter. Any reason for that? Sup doesn't clear on step 7 which means pulse count wasn't saved. What prevents pulse count from being saved in clc
Posts: 270 Likes: 2
Posts: 270 Likes: 2 |
Go back and check all adjustments especially 62-69
Posts: 22 |
Might want to check the encoder and also could possibly be the clc. Also make sure that you getting the dol and the dcl leds to light on the door board
Posts: 318 |
Does 65000 pulses sound normal?
Posts: 206 |
Sounds high to me, last one I did was 490.
Posts: 22 |
Sounds high to me as well I think that the last one I set up was 675
Posts: 318 |
Does the high tach prevent the save. Will try to replace the tach
Posts: 805 |
I know this sounds simple, but a lot of the time new belts can fix a problem like this. If they slip even a little the encoder counts are off. Just something to keep in mind.
Posts: 194 |
..might want to changeout the motor had a problem recently on two of my cars at random jobs..
Posts: 215 |
I'm with John jay on this one. At least try and tighten the belts before going for an encoder.
Posts: 1,769 Likes: 12
Posts: 1,769 Likes: 12 |
That should have the big black plastic, analog encoder. I have seen the little digital encoder on these when we pick up new jobs. I think they are 500 cpr, DMC won't save a travel that high. I have also got way high travel #s replacing the analog encoder switches with Sees parts, I know it doesn't make sense but it worked fine with TK parts. If anyone else has seen that or can explain it I would appreciate hearing about it.
Posts: 80 |
Make sure your replacing it with a 6300py4 board. Install the capacitor in the controller on p150 and g150. Replace all the belts. If they are dry-rotted or too tight or loose it will throw the counts off. Make sure the door close and open limits make. Good luck
Posts: 25 |
Well if your CLC is an old version the new door board won't communicate with it, then you have to upgrade all the boards.
Posts: 318 |
Ok, i've replaced motor, encoder, belts, door board. It's practically a new door op and i'm still getting a 65000 pulse count. Anyone have any other ideas
Do you get a different count if you move a limit?
Posts: 318 |
