Hi everyone,fault 11 every morning,Relay pilot leds F1,F2,F8.
I got the fault code manual but missing the Dc drive page.
This fault indicates a field loss. I would start with checking for loose connections in the Field Circuit.Why you are only getting it in the morning is unusual. Check the field Parameters. Rated Field Current should reflect the Jumper on the Field Feedback Board.
im goint to remove the Link try as soons as you can
https://www.dropbox.com/s/khlr68u6jmagglk/Drive%20DC.pdf?dl=0
Thanks guys the are loose connections on field board.
PHP: 8.3.33 Page Time: 0.020s Queries: 24 (0.005s) Memory: 3.0159 MB (Peak: 3.5929 MB) Data Comp: Off Server Time: 2026-09-20 19:20:38 UTC
