0 members (), 25 guests, and 3 robots.
#16916 04/29/16 10:54 PM
Does anyone have some info on this drive. I cannot get elevator to complete drive set up and as of now it try's to run but will not actually move. Throwing a 117, 108, and a 26. I have replaced the drive, tach, and resolver. Any help would be appreciated.
Did u learn the resolved angle
Yeah I attempted to. Since yesterday I had the Adon and cpu burn up. So now I've got a new drive, new cpu, and new Adon. My question is in which order to I set these things up. Also any additional info on this would be appreciated. I have some info but it's surely not an adj manual. Thanks guys.
Make sure all your drive parameters are set,Lon download for the new boards,tac voltage set menu 6-10 -3.610vdc,set resolver angle,adon learn next,maybe shaft setup,then loadweigher.double check all parameters!
No mention that you used test weights to set up new drive ?
Check both brake pods are working correctly.
I think you can turn it to L-50 just to get it running for time being
PHP: 8.3.36 Page Time: 0.033s Queries: 26 (0.007s) Memory: 3.0198 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-05 05:41:30 UTC
