#17217 05/31/16 10:24 PM
Can anyone help with error code 10- the description says its a drive fault. We were having 70 flts every other day, until we changed CPU's. Now all but one of the 3 cars are fine, except now we are getting entrapments logging a 10 flt on one car. It started after we changed a couple Lon I/O boards about a week ago. Tech is going to go back tomorrow and swap the io boards we changed before the 10 faults, but at this point we are shooting in the Dark.
Thyssenguy #17246 06/04/16 09:52 AM
No extra Extra info ?
NOTIME #17247 06/04/16 02:14 PM
1209 I believe
Thyssenguy #17248 06/04/16 02:40 PM
and a 97 code as well was present after a shutdown.
Thyssenguy #17254 06/05/16 04:36 PM
1209 is not a Extra info should another fault
1209=Missing NOde (something in comunication)or power filure in LON sometimes has 24v in controller and just 20v in Cab (for LON)
pres OK and Show you a Extra info is a Long number ex.(000100002)
97=ETSL_MISC (check Vane or any error reading the Terminal)(make a new JFL "learn trip")
10-FC_FAULT: is a Emergency Stop (suddenly)
sometimes if open a Interlock at high speed or any Charging Fault in the Drive in TX some time auxiliary contacts from SH contactors
NOTIME #17255 06/05/16 07:17 PM
Thank you, could this be caused by a flaky SB Pilot relay, it still has the original blue rather than the new black ones.
Thyssenguy #17256 06/05/16 07:34 PM
Back contacts on those blue relays have been causing ghost faults since their inception. The finder relay is trash, change it, even if it's not the problem.
Silly #17259 06/06/16 01:34 PM
Mechanic is saying there is no Extra info available for the 10 fault. But he is getting extra info 0x0003000f in the 1209 fault intermittently do you know what that is?
Do you have any info on how to put the car on wild car opp, with doors closed and stop at random flrs, would be awesome!
Dave
Thyssenguy #17260 06/06/16 01:53 PM
well
for door disable, go to menu found "Special Trip" next KFM tourn in ON
with KFM car run with door disable
press button 1 & 2 to return to Status Disply
in the Status Display
if you press button 1 an 4 at the same time you could make car calls
to return to normal go to Special trip and Turn OFF KFM
""let try to found my manual for extra infos""
and yes Fault 10 has NO extra info wink
PHP: 8.3.33 Page Time: 0.033s Queries: 32 (0.010s) Memory: 3.0356 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-21 06:10:21 UTC
