1 members (solidstate),
Posts: 3 |
I have two tac 20 in same machine room , both UIT screens Not working , have like four little dots in middle left corner. Can these boards be Swapped or are they job specific. Can they Be disabled thru IMS? Any suggestions ?
Posts: 20 |
In my experience.. I called vertical express I was trying to replace the screed with the same problem on a TAC22 Non-Proprietary and they said the warranty was expired and we need to contact a local TK company, I also tried to swap it with another controller and it did not work. I have an IMS tool and it works on that controller and its 100% better than the UIT screens.
Posts: 1,766 Likes: 11
Posts: 1,766 Likes: 11 |
The UIT is fingerprinted to the job on TAC20s. Most likely someone has either installed a UIT from another car or loaded software not for that job. If you have IMS though, I wouldn't even bother with that thing. And having it disabled just gives building engineers and maintenance people one less thing to screw with.
Posts: 3 |
Thanks for your inputs, I don't have the IMS yet. It is nice to have just to show status. Next time I am there I will try to swap them .
Posts: 20 |
If you need ims I can help you.
