#17399 06/29/16 07:52 PM
how can i use 3rd party access key card on shindler 3300
GDB
GDB
Just wire your card reader relay into the key switch on the cop and set it to a floor in the paremeters
Shindler 3300 has access called SASA
Cop doesn't has any key switch
how can i connect relay reader on cop and where
ThyssenKrapp @
GDB
GDB
Take off the COP and find input X-KEY then use relay from card reader to input signal and assign to a floor in parameters
thanks alot ThyssenKrapp
if i want to make card reader for all input calls on COP
what should i do ?
GDB
GDB
Either Buy the SAS system from Schindler or contact MODUSYSTEM and replace the COP with standard buttons using their driver board then you can do what you like with the calls
Would it not be easier to assign a pin code to all floors in the parameters using the existing software?
SAS system is very expensive
if i want to use 3rd party reader
what should i do?
PHP: 8.3.36 Page Time: 0.030s Queries: 28 (0.010s) Memory: 3.0268 MB (Peak: 3.5926 MB) Data Comp: Off Server Time: 2026-11-06 09:10:32 UTC
