0 members (), 16 guests, and 2 robots.
Posts40,945
#17532 07/16/16 01:17 PM
Hi everyone,
I have an LCB2 board that it must be replaced. He have spare board to replace it but here is the problem:
When we replace the board with one with the same code (G01 LCB_II) the elevator works fine (we use the EEPROM of the old/broken board)
When we replace the board with a new with the code G02 LCB_II the system does not work fine (stops bettween floors... and no errors occurs on the LCB log nor at MCB)
Anyone knows of this problem? Is there any solution??
Thank you@
The 3 dip switches in the middle of the board is in the same positions?
Do only change the eeprom? Is the software eprom the same version?
If the boards are the same you should have a part no like this:
GXA21240D1 (This board is fully populated, all features).
D2-3-4 is partially populated, not all features. D3 is only for hydraulic elevators.
PHP: 8.3.33 Page Time: 0.016s Queries: 18 (0.003s) Memory: 2.9983 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 21:29:07 UTC
