#17535 07/16/16 08:07 PM
I have a transformer that is reading only 1.3 ohms between h1 & h2 on primary side. The reading increases .1 ohm as I measure between h1 and other taps as expected. My question is, isnt this Reading way too low, indicating a short? Thanks in advance.
Is it burnt ? Are you blowing fuses before it?
Trips breaker as soon as starter kicks in. Ended up being fault contactor defective. I guess the transformer reading was accurate
Transformers and other windings use Inductive Reactance after the Voltage is applied. The Ohmic Value with no Volatge is inherently low.
Ive chased a couple of shorts back to a transformer I had forgotten to unhook while looking for the cause of a blown fuse.
PHP: 8.3.33 Page Time: 0.022s Queries: 24 (0.007s) Memory: 3.0145 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 05:21:32 UTC
