Posts40,945
Page 2 of 2 1 2
Elevator Guy
Elevator Guy
Add 200 lbs to car. Or 126 brakes dragging. I just wrote this long post about factory, sheave cut , didn’t go to server probably missing ballist weights and there is the start of it. Look on the job prints for rope compensation weights
I had this issue before. I wouldn’t suggest putting degreaser or cleaners or mineral spirits on the rope, it will get into the core. I mounted a piece of carpet on the cable luber and ran it top to bottom for a couple hours changing the carpet for a clean one every half out or so. I Also went over the ropes individually with rags and wire brushes. Then. I through the rope luber in the garbage! Guys put these right under the machine because that’s pretty much the only place to put it then the lube goes all over the machine/ brakes. Mind you this thing was full of oil and jammed tight up against the ropes. Ur if it get on the brakes you hav e whole new set of issues
Page 2 of 2 1 2
PHP: 8.3.33 Page Time: 0.052s Queries: 19 (0.014s) Memory: 3.0194 MB (Peak: 3.5924 MB) Data Comp: Off Server Time: 2026-09-21 19:15:57 UTC
