#18232 10/03/16 05:46 PM
Car levels fine in the up. In the down it stops an inch low - door opens then it levels up perfectly. Would that be a DC AdJustment? Thank you
JimboNJ #18233 10/03/16 05:50 PM
Can you feel a transition from High speed to leveling speed and have a couple inches of stabilized leveling speed?
Rolly #18235 10/03/16 06:09 PM
Yes
JimboNJ #18236 10/03/16 06:25 PM
DC should be it "IF" DC Screen is clean. If it doesn't check your down level speed, may be to fast.
Rolly #18237 10/03/16 07:08 PM
Boa Offline
Agree with Rolly, you should have 2 to 3 inches of stabilized leveling about 10 to 14 fpm, if not check the DC screen then adjust if necessary. Also I'd check the coil to make sure if car is, shows if valve or electrical.
https://www.elevatorequipment.com/eeco-valve-app
check this app out it should help
Boa #18451 10/24/16 07:58 PM
Thanks guys
PHP: 8.3.33 Page Time: 0.037s Queries: 26 (0.008s) Memory: 3.0185 MB (Peak: 3.5924 MB) Data Comp: Off Server Time: 2026-09-21 12:14:38 UTC
