#18398 10/20/16 12:18 AM
Car will arrive at floors doors will not open. Not automatically or by door open button. Will open if you manually trigger SE relay. Then they will close and safety edge will not stop door from closing. Help please. All IBM relays are tested ok.
You are on the right track
SE relay on dover is for your safety edge and door opening circuit.
Did you try to replace the relay?
If so, do you have any voltage across the coil?
Check MOB, 10A, DR N/C contact, Chcek 2LR N/O contact
Look at you print where you see CS in the SE circuit. CS pulls in when you start your slow down. Then SE should pull in either when the car is at the floor or pre-opening when your in the zone...
jkh #18401 10/20/16 02:09 AM
A failure of DZ contact #4 or your door zone sensor failing to pick DZ relay would cause exactly these symptoms.
PHP: 8.3.36 Page Time: 0.025s Queries: 22 (0.008s) Memory: 3.0121 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-05 22:44:32 UTC
