0 members (), 25 guests, and 0 robots.
Topics7,434
Posts41,134
#18611 11/11/16 12:15 AM
Anyone had to micromanage an intermittent low line fault on a Robicon drive
Ben Dover #18614 11/11/16 02:34 AM
What are you using to look at fault? I believe that is a very small transformer in the back of the controller. Don't remember the name but it always caused a low line fault. Swap it with another car see if you move the problem.
Rolly #18616 11/11/16 04:11 AM
Low line LED on the drive? I've seen that caused by drive board two.
NewMech #18617 11/11/16 04:54 AM
It's an Otis 401 with a Robicon direct drive and it has a control board with fault leds. The low line led comes on once about every sixty or so runs. The processor resets the drive and it takes back off again. I've checked the supply and it is stable. Replaced the drive board and it is still happening.
Ben Dover #18620 11/11/16 06:13 AM
Replaced the board or swapped with a known good? We've had boards come back from the board shop and still throw a low line.
NewMech #18639 11/13/16 06:28 PM
Replaced with a known good one
Ben Dover #18734 11/20/16 04:36 PM
Years ago I remember fixing this problem at Monte Fiore Hospital, Bronx NY. by adding a 2.2 micro fard capacitor to the input of the operational amplifier that senses the line volts, but I do not remember the details. NO REPAIR SHOP will realty know where to look unles they have one of those electronic techs with good background in control system that also understand the DRIVE circuit diagrams.
NYTECH #18805 11/30/16 12:25 AM
Thanx I'll look into that.
PHP: 8.3.37 Page Time: 0.054s Queries: 30 (0.011s) Memory: 3.0309 MB (Peak: 3.5932 MB) Data Comp: Off Server Time: 2026-11-23 21:13:03 UTC
