#18764 11/23/16 11:20 PM
need help with a drive fault on a artira. Im sure its about ten years old
what kind of fault?
on the board of led's just has drive fault
all my other led's lit up
Did you try calling garaventa, they're normally pretty helpful.
When you do an MLR, do the hall buttons flash in a circular pattern? On a ten year old unit, I would expect them to flash. On a fifteen unit, I would not expect this. I'm trying to guess the age of the equipment. Which other leds are lit? If you have a motor drive, does it display anything? Have you tried to manually move the unit? Is it bound and cant move? Is the unit in the up position or the down position? Does the unit have a home park position or are all positions actual floor stops?
Johnny #18787 11/26/16 12:02 AM
check for continuity between the steel cable and the tube. Been having lots of issues with this and garaventa has told me its best to change the cable. the 24VDc feed connection point can fray which in turn shorts out against the tube. it's near impossible to get at the connection point. Need to pull the carriage off.
Sammy #18790 11/26/16 04:37 PM
ok i will try that thanks.
PHP: 8.3.33 Page Time: 0.034s Queries: 30 (0.006s) Memory: 3.0299 MB (Peak: 3.5924 MB) Data Comp: Off Server Time: 2026-09-21 15:06:56 UTC
