Page 2 of 2 1 2
Dandroid #19326 01/24/17 03:52 PM
Well, crap. The sucker ran fine for over a month, and just this morning tripped that same fault. Just once. Reset and it works great. Selector fault 06. No other faults in the controller, besides the CLC selector monitoring fault (025, I think). All 3 selector boards have been changed. New clc with different chips. Good hoistway scan. Nothing wrong with the limit switches on visual inspection.
Dandroid #19331 01/25/17 01:10 AM
not sure if you know, the DZR switch is not part of one of the 3 selector boards you replaced, it mounts to the selector housing and then plugs into the main selector board. just checking to see if you understand that ,since you reposted the same message again. as idwt says thats probably it, can't hurt to change it.
Dandroid #19334 01/25/17 03:40 AM
did you change the door zone reed switch?
Page 2 of 2 1 2
PHP: 8.3.36 Page Time: 0.064s Queries: 21 (0.046s) Memory: 3.0250 MB (Peak: 3.5926 MB) Data Comp: Off Server Time: 2026-11-04 21:28:53 UTC
