1 members (Johnny), 24 guests, and 2 robots.
#18942 12/15/16 04:45 PM
Working on an Otis gama D or spec (not sure which) I have picture I can email. Door controller is big silver box with Contacts O1thru O7 and C1 thru C7 ....The door open is intermittently hesitating a few inches into the open. I have cleaned all the open contacts thoughrouly. Still having same problem. Any advice on where to start with this controller.
Jluff #18949 12/16/16 02:02 AM
Sounds like a QL operator. I would make sure you aren't momentarily losing your DZ signal. Not sure about Spec 60, but Gamma D uses a narrow tape; worn guides can make this happen.
Yea that makes sense. I had that once with a swift . I will check the selector out when I get back there.
Jluff #18951 12/16/16 03:15 AM
I Online: Content
I've seen something similar on 2 QL operators caused by a brake in the resistor wire under the tap. Both times it was the same resistor, back right corner if you're looking from on the car.
I would suggest checking the resistors and contacts for breaks of wire or connections, in the area/contacts where it starts to fail, although its a good idea to check the whole lot. Check the continuity whilst wobbling wires about. It could also be having a high resistance under load conditions.
uppo72 #19018 12/27/16 01:26 AM
I have a setup procedure for QL operators . Pm me if you want it , worn bearings on the small A frame that holds the cam rod can cause intermitant making and braking of the switches . Any excessive wobble will give you problems
pieman #19171 01/10/17 08:48 PM
Txs for all your advice. I went over everything thoroughly and the problem immediately stopped. However it started happening again. Lol. Does any one have advice on an upgrade for this operator ?
Jluff #19175 01/11/17 12:55 AM
Have you looked at the open and close relays/contactors in the controller? Whether these are the black Arrowmat or the white Sprecher, they will aventually give intermittent problems like this.
I Online: Content
If the problem went away after touching everything I would mark and pull every resistor tap. There's probably a broken wire under one.
PHP: 8.3.36 Page Time: 0.027s Queries: 32 (0.008s) Memory: 3.0361 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-04 22:58:53 UTC
