#19079 01/03/17 08:18 PM
having a problem with miconic A ,it switches into Block operation , switches back to normal ,any ideas ??
rovor #19082 01/04/17 12:59 AM
It's probably dropping out of the group. Does it go to random floors when in block operation? Try reseating the cat 5 cables for car to car communication
Jcjphoenix #19083 01/04/17 02:19 AM
yes it does hit random floors like a half assed wild car operation ,I have reseated the cat 5 plugs and all the plugs for that matter even tried swapping mtv board
rovor #19084 01/04/17 03:18 AM
Maybe try changing cat 5 cables. I had some going into block operation because when you open swing panel that MTV is mounted on to get to drive, the cat 5 cable on the top right of the MTV would get in a pinch. I could always just reset cable but maybe yours has a damaged connection? .
Jcjphoenix #19107 01/06/17 12:00 AM
good point ,its a duplex , ill swap with other car and see if problem follows ,thx
PHP: 8.3.33 Page Time: 0.042s Queries: 24 (0.007s) Memory: 3.0146 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-21 01:51:01 UTC
