October
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
10,053 Registered Users
Topics7,404
Posts41,025
Members10,053
#19241 01/19/17 01:01 AM
Hello Guys,
Otis Gen 2 problem. Elevator runs on mr inspection, runs on car top, runs on fire service. Will not run on normal operation.
Testing guys at site day before, everything ok when they left?
Saw G003 fault, now cleared.
Won't take calls.
Any ideas
chicago #19246 01/19/17 01:32 PM
CHCS switch?
DDOS switch?
Do you have a DLF displayed on your car monitor?
NewMech #19262 01/20/17 01:01 AM
When was the unit installed? You may want to check the controller backup batteries at the bottom of the controller. If they are starting to get weak it can cause similar issues. They need to be replaced I believe every 5 years or so.
'Way to go, ace.'
vader potater #19263 01/20/17 01:54 AM
If it is the batteries OCSS will be NAV and there will be a current fault that won't clear, don't remember which. Don't rule out the batteries because they read the correct voltage!
Indirtwetrust #19265 01/20/17 02:51 AM
Problem was flat belt sensor.
Time to change cables(belts).
Turned off sensor, car ran.
chicago #19281 01/22/17 02:36 AM
Which key unlocks panel that gets to controller?
beaupeep #19285 01/22/17 11:27 AM
I think it's a UTB or UTC to unlock panel. How do u navigate thru the menus to get to the belt sensor with the service tool?
Jluff #19309 01/23/17 09:15 PM
You need to hook up fast tool too "installation" port then proceed to flat cable ohm sensor.I left my notes on how to navigate on job.
PHP: 8.3.35 Page Time: 0.057s Queries: 30 (0.022s) Memory: 3.0302 MB (Peak: 3.5924 MB) Data Comp: Off Server Time: 2026-10-11 03:34:57 UTC
