Page 1 of 2 1 2
#19312 01/23/17 11:28 PM
I've got a kcm831 with a v3f25 drive. The car is over shooting floors up and down by an inch or so. Then it relevels into floor perfectly when the doors are almost fully opened. I have codes and parameters but no drive parameters (menu 6). I'm sure the releveling speed and the slow speed the car travels at while leveling into the floor while on auto are different settings. Does anyone have a list of the drive parameters for a v3f25 or at least what I can change to get the floor level correct as it comes into the floor the first time.
Jcjphoenix #19341 01/25/17 11:05 PM
Definately always turn off preopening. I don't have any written down, I'm sure Rolly or Koneisland can chime in here...
E-man #19364 01/27/17 06:02 PM
I'm sure now I'm not able to learn the hoistway correctly. I keep getting an 01 18 error when I try. The guy before me had to replace one of the magnetic sensors that was locked up and he might have moved something. I don't have any fault code lists that have an 01 18 in it. Any help would be great
Jcjphoenix #19365 01/27/17 06:38 PM
Check the sub code,6010 is min.overlap is 10mm,6011 max.overlap 20mm.you need to spread the cigar switches closer together or further apart.
lowoil #19366 01/27/17 07:08 PM
The magnets for leveling and door zone are all doubled up, one on top of the other which doubles the magnetic field. I'm not sure why this was done that way because it increases the dead zone. The sensors can be within 3 inches of the magnet and come on.
lowoil #19367 01/27/17 07:37 PM
Jcjphoenix #19368 01/27/17 07:39 PM
It's sub code 6010
Jcjphoenix #19369 01/27/17 08:00 PM
I think you need to move them closer together a little then repeat set up
lowoil #19370 01/27/17 11:29 PM
Look at last couple pages of prints. Shaft vane diagram there with measurements on it. Shows where everything belongs.
Rolly #19371 01/27/17 11:35 PM
Thanks for the tips. I'll compare everything with the diagrams monday.
Jcjphoenix #19391 01/30/17 02:47 AM
BRG Offline
The magnets are doubled up because of the gap/clearance needed for the switch and magnet. Single-stack them and you will wipe out the switches on the rail clips. If you have magnets for 61u, 61n and 30 you don't have a V3F25 drive. You have either a KDL16 or a V3F16L, depending on the age of the unit and if it has been upgraded or not.
When you're parked in the middle of the 30 magnet, move the 61u switch up until the led on the CCBN goes off, then move it down so it comes back on. Move the 61n switch down until it's led goes off then move it up until it comes on. It's been a few years since I adjusted these critters, doing my last years in the service department, I think the starting distance between 61u and 61n is something like 5.25 inches. I'll look through my literature and see if I can find it. You will need to run another shaft learn when the switches or magnets have been moved.
BRG #19392 01/30/17 03:43 PM
I've got a v3f25 drive, I'm looking at it now. And it does have 61u,61n,and 30. The building maintenance guy said they've had leveling issues since it was installed in 2009. When I've got the gap between the sensors and magnets at 3/8" , I have to move the sensor almost 2" up or down away from magnet before the led goes off. I've tried increasing my gap but that leads to inconsistencies. It's like the magnets are way to strong or the sensors are way too sensitive.
Jcjphoenix #19393 01/30/17 04:04 PM
Like I said before move the cigars closer together with that 118 6010 fault, I've adjusted dozens of cheapo spaces and that fault comes up when running a shaft setup
lowoil #19394 01/30/17 04:05 PM
Don't worry about when they come in and off start with the cigars a fuzz past the magnet
lowoil #19396 01/30/17 09:52 PM
BRG Offline
Is the drive in the top or bottom of the controller? At the end of the shaft learn the 118 fault will show up. Cycle the power and see what happens. If the rail has become so magnetized that it is activating the switch I suggest marking the magnet locations, removing the magnets and beating the rail with a 3 pound sledge to get rid of the magnetism in the rail.
There's an easy, but time consuming, way to get the unit to hit dead on level in both the up and down direction.
BRG #19399 01/30/17 11:21 PM
Drive is at the top.
Jcjphoenix #19400 01/30/17 11:31 PM
As its running the scan I'm sure it's logging a 118 fault at each floor. I noticed today that it had a 118 6010 at all floors but the 2nd where it had a 118 6011. All the magnets are the same length and I've checked to see if rail was magnetized and it was not. Brg, you mentioned that a v3f25 should not have sensors and magnets for leveing. I wonder if this unit was altered for some reason and it's had this issue ever since. It just doesn't make sense how it's supposed to be able to do a floor scan and then be able to relevel properly with the system of sensors and magnets acting like they are.
Jcjphoenix #19401 01/31/17 12:22 AM
Are all you magnets at the same spot on the rail? Either all in the corner of the blade and back? And Gap must be 3/8" between cigar switches and magnets. It is important to have your spacing between your 61 u and 61 n proper. I'm pretty sure it's 150mm. I'd have to double check. Everytime you move magnets you have to do another hoist way scan
Amicrazy #19403 01/31/17 12:33 AM
Yes, my placement,gap,and spacing have all been correct. I've also tried adjusting the gap,and going in and out with my spacing , a little at a time as far as I can go , and I've tried a new hoistway scan with every adjustment. Maybe be unit is running to fast while doing the scan?
Jcjphoenix #19404 01/31/17 01:25 AM
There is a V3F25 S for Serial even through the drive and controller won't have an S anywhere. I think I was told if it's 4:1 than it's an S. I'm never t sure but maybe the S version has the 61U, N & 30 switches. Also some of the procedures are different on the S version.
Page 1 of 2 1 2
PHP: 8.3.36 Page Time: 0.032s Queries: 55 (0.009s) Memory: 3.1197 MB (Peak: 3.5926 MB) Data Comp: Off Server Time: 2026-11-05 02:24:40 UTC
