October
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
10,053 Registered Users
Topics7,404
Posts41,025
Members10,053
#19466 02/07/17 02:43 AM
nvatorm
nvatorm
I changed the packing on a tac 20 and left power off for 2 days b/c I had the wrong size and had to overnight the correct packing.
I finished the repack and turned power back on and the elevator:
1) will only run on inspect.
2) will level up or down to a floor but always about 2 inches low.
3) I swapped the selector with a known good
4) I swapped all the 24vdc & 110vac relays with the exception of the 12 at the bottom of the main controller board. (there are 12 and some of them control the valves)
I was told that the battery on the cpu may not have had enough power to hold the programming for 2 days, would this cause the problem I have? What else could it be?
nvadorm #19470 02/07/17 04:34 AM
nvatorm
nvatorm
5) The elevator doors will sometimes open and then close slowly after the car levels down to the 1st landing when I take it off of inspect.
When I reset the door operator it usually does a learn run, but now it just opens and closes slowly once.
nvadorm #19474 02/07/17 05:23 PM
Are you using a service tool?
Did you create a job file?
When was the battery last changed?
What faults are shown on the tool?
jkh #19477 02/08/17 12:17 AM
Does (2003) mean it was put in in 2003 or it's a TAC20-03?
You are really going to need IMS to get any further with this.
nvatorm
nvatorm
The 3v battery on the main control board wasn't making good contact. I spun it around to look at the model number and the elevator started working on automatic.
2003 was the installation year.
No service tool frown ... Although I would like to get one.
Where is the best place to get a service tool?
Vertical Express?
Anywhere else?
Will they only work for a specific job or specific elevator?
Do you have to renew them annually?
PHP: 8.3.35 Page Time: 0.052s Queries: 24 (0.010s) Memory: 3.0155 MB (Peak: 3.5922 MB) Data Comp: Off Server Time: 2026-10-11 02:51:33 UTC
