#19538 02/11/17 03:20 PM
Adjuster
Adjuster
Just got a new bldg with tac50s. The car runs fine on inspection in the down, but in the up it shuts down after 1 run with a 1547 bslm. Brake swts look fine. Not sure if it's a tach issue since it's directional. My faults on my service tool doest have 1547. I don't have any manuals or fault log books. Any idea guys?
DJ 411 #19542 02/11/17 04:23 PM
Car Fault: 1547
Fault Description:
BSLM2 Showed Brake Picked when Brake should be dropped.
Rolly #19544 02/11/17 06:13 PM
Adjuster
Adjuster
OK, thanks. Brake seems to be OK. Runs fine down but faults in the up.
DJ 411 #19545 02/11/17 06:13 PM
Adjuster
Adjuster
Thanks for the info....
DJ 411 #19547 02/11/17 07:57 PM
The brake switch inputs are susceptible to noise. They should be in shielded cable with the shield grounded on 1 end. You can also wire a resistor from the inputs to P24 to keep them honest. What kind of machines are you working with?
BTW, I've never even seen BSLM2 input used before. And I only found that fault in the TAC32-T manual.
Adjuster
Adjuster
DAB 530 gearless.
DJ 411 #19658 02/22/17 12:48 AM
U could have a roll back issue. If you have a 10k drive increase karb adjustment on the drive to limit rollback on your start
C not #20066 03/31/17 01:07 PM
Adjuster
Adjuster
Thank you for good info. Is there a pick sequence that the process of looks at, like balm needs to pick before bake or has to drop out first? I get run monitor faults if the brake switch are a touch out of wack.
PHP: 8.3.36 Page Time: 0.050s Queries: 32 (0.013s) Memory: 3.0351 MB (Peak: 3.5926 MB) Data Comp: Off Server Time: 2026-11-04 19:07:16 UTC
