Had water damage on a door board. Got new board from thysen. Hd-04 operator has 3 ph door motor that running the wrong direction now. I tried reversing 2 leads in all combinations. Door just shakes back, and forth, and faults out. Is there a phase monitor on this operator? How do you change motor rotation on this. There is a encoder attached to the motor. Any help is appreciated.
Software.....Do you have IMS? There is an apadter needed to hyperlink directly to the door board as another, more preferred, option. If you don't have either of these, get one of your Thyssenkrupp friends to give you a hand. Takes around 5 minutes if all goes well to drop the software on and rescan.
I do have Ims is it just door parameters I need to change?
I need a adapter. Do u have a part #? Or what to ask for?
408-324-6901
Moe, computer shop in San
Francisco for $175.
Thanks so much for the help. Equipment keeps changing we keep learning
Is this the same adapter for Tac 20?
It is not the same, just confirmed with a Thyssen Tec.
You can change LHO with IMS but if you swap two motor leads you need to swap the encoder. That should work too. This is the same board used on all but the oldest TAC20s.
Hello dear friend,
we need technical manual of thyssenkrupp CMC4 lift control.
also the car board UCC-CMC4 and VF08 thyssen door operator.
bets regards
PHP: 8.3.33 Page Time: 0.022s Queries: 34 (0.006s) Memory: 3.0421 MB (Peak: 3.5922 MB) Data Comp: Off Server Time: 2026-09-21 01:54:38 UTC
