Page 2 of 2 1 2
Incidently I have over the years serviced lifts on what we called caretaker maintenance ie 4 times a year. We shut the lifts down, when completed. Even with that program phones were required, however I did hear of lifts shut down and essentially not serviced and kept up to date ie phones as well. However, when they were turned on again, they had to be brought up to date again, including phones, but also potentially other systems that were ok, whilst continuous use was happening. Not the best way in the long run, and you still would be liable in the case of someone happened to get stuck in it. I wouldn't recommend this way at all.
Originally Posted By: Indirtwetrust
You misunderstood. Otis had and still uses a remote monitoring system for the elevator like other companies have done and as TKE is releasing a new version of now that you see on your TAC-20. These are for monitoring of performance, shutdowns & predictive maintenance. They have never been intended to replace the life safety device in the elevator that allows a trapped passenger to call for help and get that help in the event of an emergency. BTW, a building with low to no occupancy poses the greatest risk. If the phone does not work and no one can hear the alarm, someone could be trapped indefinitely. If you end up with someone stuck in your elevator over a long weekend and have "cut" the line as you suggested, you will be sued. And you will loose! Maybe you didn't hear about the woman who died in an elevator in China last year for this very reason.
Thank you for the response.
I suggested that other person may just cut the lines however I am trying to do the right thing and asking questions on this forum to setup an alternative method.
The building is not 100% abandoned. There is still a small company on the ground level however I do understand what you are saying.
Thanks.
Page 2 of 2 1 2
PHP: 8.3.36 Page Time: 0.030s Queries: 19 (0.009s) Memory: 3.0218 MB (Peak: 3.5932 MB) Data Comp: Off Server Time: 2026-11-04 19:02:42 UTC
