0 members (), 36 guests, and 2 robots.
Page 1 of 2 1 2
#1437 05/16/11 11:02 PM
I am wondering if anyone knows if it is possible to perform a TFS command on a Thyssen TAC 50 without the hand held tool? I have the IMS tool in place but it is limited and it is necessary to perform a tach fault reset. Thanks in advance for any help.
Elev8rdan #1442 05/17/11 06:26 PM
Correction I am trying to perform a TFR command(tach fault reset)
Elev8rdan #1454 05/22/11 03:54 PM
You can buy a UIT which mounts ontop of the CPUA. You will be able to reset faults ( like the tfr ) and view faults etc. You can actually fully adjust a tac50 tru this interface. Other then the UIT, IMS is required. POR ( Power off reset's) don't clear these sort of errors and so they shouldn't in my opinion.
Oh and btw the IMS tool is not limited at all you must have "Owners" version.
lepricon #1497 05/31/11 01:55 AM
I think a CPUA board is on a TAC50-04 not a Tac50 which is similar to a T4 with PMI DSP and CPU Cards in a Card Rack. A UIT is not made for a Tac50, you must use IMS.
nuElevatorGuy #1609 07/25/11 06:08 AM
I have a hyperterminal software. Can it be used to view fauls and conduct resets on a TAC 50 controller?
AMADF #1666 08/15/11 03:00 AM
i think this command TFR only is available through IMS for TAC 50 controller because dont have the UIT port
AMADF #1673 08/17/11 06:44 PM
Ice
Ice
Hyperterminal in TAC 50 Korea is mainly used to check the faults in the drive, and change its params. If you're talking about the same controller, i cpuld help you out.
lepricon #1674 08/17/11 06:47 PM
Ice
Ice
can someone tell me what UIT is?
Bibin #1675 08/17/11 08:03 PM
UIT user interaction tool. Thyssen's way to give customers a half/assed way of working on their stuff where they get spec'ed to provide all tools needed to work on the system. It is not used on TAC 50.It is a little LCD display that gives you menus to get into the system. They are better than nothing.. but not much. IMS is really what you need. I have only seen the UIT on a few TAC 20 jobs.
Smitty #1728 09/01/11 09:26 PM
Tet Offline
I am in need of a service tool for TAC 50 03. Anyone know where i may buy one?
Tet #1739 09/04/11 03:30 AM
check in world electronic the lap with freedom tool w/software for TIV because TIV and TAC50 are the same in communication the only difference is the communication speed your TAC50 have boards CPU,DSP and PMIs right
djenergy #3040 03/23/12 12:57 PM
We can sell IMS software with unlimited license to you, for more information please contact me, [email protected]
hmbx #4306 08/09/12 05:58 PM
What is command in remote fast I need to enter to view load weighed info in real time
Rick #4307 08/09/12 06:14 PM
I'm having a rollback issue on gd1 machine w/ 663 fault and wondering if load weigher is problem . what is command I need to enter in remote fast to view changing load states
Rick #4339 08/13/12 01:27 AM
Hi there
DLW is the command to look at load data.
In the drive change your EPT to 1
Make sure M98=1 (pre torque enable)
Bump FLD up to .800
Make M39 (Acceleration) lower
If you are still faulting out you can play with the start delay time M43.( Longer is better for roll back issues )
What does the car do when you run with zero speed on inspection.. does it still fault out?
You might have encoder issues.. you are actually getting an excessive torque fault.
Let me know what happens
lepricon #4356 08/14/12 06:41 AM
If any one need IMS software feel free to contact me : [email protected]
lepricon #4513 09/02/12 01:40 PM
Your info took care of rollback thx. 663 was caused by minor vibration of bad IOC.
Rick #4521 09/02/12 09:56 PM
How much is the Ims software? Might consider it.
Elevatorfella #4526 09/03/12 02:23 PM
E-fella,
Try world-electronics.com
jkh #6996 05/13/13 02:30 PM
IMS 4 sale
IMS 4 sale
Have IMS software w/ laptop and cables- inquire for more info and costs.
IMS, Fast tool, Coco tool, Door Fast tool, Miconic, Hyper Terminal For sale.
Page 1 of 2 1 2
PHP: 8.3.36 Page Time: 0.047s Queries: 55 (0.018s) Memory: 3.1155 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-05 01:19:56 UTC
