Page 1 of 2 1 2
#19888 03/16/17 01:42 PM
Got a gen 2 Mrl 4 stop. Keeps intermittently shutting down top floor on Saftey chain open.. have to hit the gov reset button to get back in service. Any ideas of why this may happen ?
Jluff #19889 03/16/17 01:58 PM
You checked tail sheave in Pit? Really need a fault list.
Rolly #19891 03/16/17 02:02 PM
Where should I go for fault list ?
Rolly #19892 03/16/17 02:03 PM
Gov reset or UCM reset ? Hitting gov reset shouldn't do anything unless your in safety test function I thought ?
pieman #19893 03/16/17 02:06 PM
It's the trip reset button
Jluff #19894 03/16/17 02:20 PM
have you checked the car speed, and Governor trip speed with a tach?
john jay #19896 03/16/17 03:04 PM
I will do that n gather more intell... no one is getting trapped in it. It's always level at the top landing.
Jluff #19901 03/16/17 09:59 PM
check gov sheave depth with gauge an make sure tail sheave switch arm in center of two bolts
DripCan #19904 03/16/17 11:10 PM
Have you put your eyes on the switch itself to make sure it is resetting fully every time?
Indirtwetrust #19912 03/17/17 01:45 AM
It's been on the top floor each time. So I cannot look at switch until it's reset and running But it appears to be in proper position I will b back soon as it happens once a week.
Jluff #19920 03/17/17 09:19 PM
sounds like your resetting UCM reset not gov reset if it was gov you would know where faults are you have to use tool for gov reset pushing button does nothing with out tool
DripCan #19921 03/17/17 11:39 PM
That's what I thought. Gov reset should only be operative if in safety function mode through the service tool . Sounds like you are either hitting CPU or UCM reset. Or are you going in through the tool to reset the governor ?
pieman #19927 03/18/17 12:38 PM
I have service tool. Just never had any training on it I have to learn everything on the job as I go. I can view the shut down messages which was Saftey chain and drive. I thought it was the gov reset I was pushing. It sounds like I'm wrong
I will try to get fault list next time. I was just asking for some guidance to navigate thru tool to them.
Jluff #19928 03/18/17 12:42 PM
I was doin power on resets thru the tool and it wasn't resetting and checking the shut downs. That's all I did with the tool Then the shutdowns cleared after hitting what sounds like a reset on the controller in door jam on top floor That's what I thought was gov reset
Jluff #19930 03/18/17 01:39 PM
No worries jluff just trying to establish what is happening . Haven't worked on a true MRL Gen 2 in ten years ( that was the only type of Gen 2 in the u.k where you don't need. Controller space ) . All of mine here have the controller exterior . With that type of controller the gov trip / reset button is a silver button on the maintenance panel above the moveable circuit jumper on the right hand side side ( above controller inspection controls ) it only functions if you go in to safety test functions ( m-2-2-5-1 on service tool ) and scroll through until you come to Gov trip or gov reset . You enable one or the other and then the button should work ( or quite often not as the solenoids in the governor tend to pack up ) . The buttons on the board are UCM reset button and CpU reset button . I don't know the setup in the door jamb with the controller in the hoistway tho to be honest so it could be the Gov trip/reset you are hitting . The fault lists you should look at are the OCSS event list ( M-1-2 ) the MCSS event list (M-2-2-2 ) ( this is the most important one ) and the DBSS ( M-4 ) . With the drive there are two fault logs one gives you a history in a format that looks like this
F58 R20 F56 R45. Etc ....
The f number is a fault code and the R number is the amount of times it ran between the faults . To clear the ocss and mcss fault logs go into the log to view the faults and hit blue 5 blue enter . To clear the drive faults is an option at DBSS menu.
Next time you get the fault make a note of all the info in the above event lists and then clear them all . Let us know what they say . Hope this helps .
pieman #19931 03/18/17 01:50 PM
Thank you pieman. That helps a lot
Jluff #19932 03/18/17 02:07 PM
If it is the UCM reset you are hitting ( and after certain faults you have to ) and the elevator is faulting out at floor level I would have said a very likely culprit is the brake switches , as they are quite a common fault . However that would not explain why always the top floor ? When the fault happens do you find it bang on floor level at the top ? I'm wondering if you are getting 'roll back ' when trying to go down from the top ? Anyway ...take a look at the logs/ events and that should point us in the right direction .
pieman #19944 03/20/17 10:29 AM
check level and slow speed magnets at top floor then you have to make learn run
rami410 #19946 03/20/17 11:24 AM
CAN YOU TELL WHICH CONTROLLER BOARD YOU USE
GECB I OR GECB II OR TCBC
if you have the service tool (AND THE CONTROLLER IS GECB II) , when you connect it you have
1 GECB 2 DRIVE
PRESS ONE TO ENTER THE GECB
THEN PRESS 1-2-1 READ THE EVENT LOG
IN ORDER TO ERASE THEM PRESS BLUE 2
THEN PRESS MODULE 2 TIMES
THEN PRESS 2 TO ENTER THE DRIVE
PRESS 2-1 READ THE FAULT
IN ORDER TO ERASE THEM AFTER U ENTER THE DRIVE MENU
PRESS 2-2 BLUE ENETR
IF YOU CAN GIVE ME THE EVENT LOG FROM GECB AND FAULT LOG FROM DRIVE I CAN HELP YOU
IF YOU LIKE ILL SEND YOU MY PHONE NUMBER AND YOU CAN CALL ME WHEN YOU ARE AT SITE
pieman #19947 03/20/17 11:26 AM
if the problem is from brake switched it will give BS1-BS2 fault, and not all gen2 have brake switches.
Page 1 of 2 1 2
PHP: 8.3.36 Page Time: 0.045s Queries: 55 (0.018s) Memory: 3.1166 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-06 06:02:48 UTC
