0 members (), 23 guests, and 3 robots.
#20371 05/01/17 12:20 PM
Does anyone have a test procedure for the clc to check for proper voltages.
Tony D #20380 05/01/17 11:19 PM
Ck1 Offline
You should have at least 5vdc across the D72 diode on the top left of the CLC board.
Ck1 #20384 05/02/17 04:09 PM
Thank you I will check on that.
Tony D #20386 05/02/17 06:50 PM
At what voltage should the battery be changed? Do you change the battery with the power on ?
Jluff #20390 05/02/17 10:39 PM
I pulled one once after a power off and it was 1.7 volts and still holding the memory. I wouldn't trust it though, I'd replace it if it was under 3 volts but that's just me.
E-man #20392 05/03/17 02:19 AM
If you don't know how old the battery is and there is no date written anywhere, just replace it and write the date somewhere. Batteries are cheap. Slip a piece of paper on top of the battery before pulling it out so the holder doesn't snap closed and short out your CLC. Set the 5v PS for 5.1 vdc at the CLC and the 12v to 10.75 vdc at the PS.
PS?
Jluff #20400 05/03/17 10:25 PM
Power Supply
PHP: 8.3.33 Page Time: 0.032s Queries: 30 (0.010s) Memory: 3.0292 MB (Peak: 3.5924 MB) Data Comp: Off Server Time: 2026-09-21 18:18:00 UTC
