#21230 07/25/17 01:10 PM
Y
Y Offline
Dear All,
Could you help, please?
Gen2 Regen stopped with error 713 Block by 208, the first problem happened did power supply reset then the lift ran normally for 3/4 days only. 208 error means a fault on the capacitors of DC link, but we can't find any problem on capacitors. Any an idea about this issue?
Thanks in advance
Check the batteries. Even if they read good they still need to be replaced every few years.
Y
Y Offline
Dear Jluff,
which battery do you mean?
Y
Y Offline
Lift OK after changed the GDCB part number ACA26800KT1.
Thanks ALL
Y
Y Offline
after 3 days working well, lift again shut down with the same the error " error 713 Block by 208 "
Drive caps are getting weak. If you can source new, replace them. This is a known issue on newer drives, there is an upgraded drive available from Otis.
Y
Y Offline
lift working well after replaced 3 contactors inside the drive
PHP: 8.3.36 Page Time: 0.027s Queries: 28 (0.009s) Memory: 3.0268 MB (Peak: 3.5926 MB) Data Comp: Off Server Time: 2026-11-05 03:41:24 UTC
