Have a dover WCR that will not stop at main landing on fire service. The car will open doors of car is at floor, but if I turn on FS at other landing it just goes to terminal landing to terminal.
Phase 2 works. What relays tell car to stop at Main landing? Main landing is 2nd stop so bottom terminal landing is below main. Any ideas? Thanks
If it slows down but just keeps leveling right past the floor, it's probably a CS contact, I think it was CS1. Just had this issue a month ago.
It's not slowing down it goes right past it.
Bummer, I'll look at a print later today.
Ok thanks Don't have print with abbrv. Definition. And I have print that has a MF and AF. But controller only has a AF relay
I'm thinking CS isn't picking to initiate the slowdown because the DZ N/C contact #4.
Car runs fine on automatic.Stops at every Hall call and car calls. Just when turn on fire service phase 1, if car is not at FL. The car will just run past landing. I checked the DZ n/c contact it's ok. Any other suggestions?
mjm Offline
make sure FSL relay comes in at the egress floor. If FSL doesn't come in, car will just go to the bottom floor and not open doors.
At the slowdown you need to pick V, then CS to initiate a slowdown. That's why I suggested that contact, if it failed it would only effect CS picking when FSH is picked. So what is not happening? Does it do it in both directions? Does it step correctly while recalling?
I'll send you a sequence of operation write up
Yes it does it in both directions and is stepping properly.
Do you have schematic with abbrv. Definition of coils?
PMs sent at you
I noticed you have a lot of Dover WCR knowledge, do you happen to have a troubleshooting manual? I've got one that is driving me crazy and now wont run at all, all safety circuits are picked + OT & LO but it wont run now. It started by only running to top or bottom and leaving door open but wont even do that now. The prints don't match the conditions so troubleshooting is a nightmare.
PHP: 8.3.36 Page Time: 0.043s Queries: 38 (0.015s) Memory: 3.0523 MB (Peak: 3.5928 MB) Data Comp: Off Server Time: 2026-11-06 00:09:22 UTC
