#21523 09/04/17 01:50 AM
I am getting a f0041 fault on a KCM831 control which is supposed to be the emergency brake not picking. I've adjusted the brake and change the micro sw , i'm thinking I need to change the relays in the emergency brake module ,any other suggestions would be appreciated,
I don't have a lot of experience on the kone equipment
ubro96 #21528 09/04/17 02:55 PM
If it's intermittent I would go ahead and replace the module or the relays on it. I had one of those contacts flakey and it would only get holding voltage. The brakes themselves bind fairly easily too, adjust them with a 2 and a 4 thousandths feeler gauge as go/no go on all 4 corners.
Indirtwetrust #21530 09/04/17 04:11 PM
Make sure you have low-movement micros on them too.
ubro96 #21857 10/10/17 09:44 PM
Check and make sure the washers are loose enough to spin by hand .this will allow the brake to pick . Good luck
juan #21859 10/11/17 12:12 AM
If the washer doesn't spin it prevents the brake from dropping.
PHP: 8.3.33 Page Time: 0.019s Queries: 24 (0.004s) Memory: 3.0148 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-09-21 04:31:29 UTC
