#21561 09/08/17 08:06 PM
I'm getting an error drive 75 safety rts with extra info 170905. I can't find this anywhere on my fault code lists. The elevator is shutting down every couple of days with this code. Does anyone have this code meaning to get in me in the right direction?
Jcjphoenix #21562 09/08/17 09:14 PM
This fault is generated when door operator reports doors reached fully closed limitand after waiting some time the hatch door locks are still not made
The Saftey circuit is open (sdoor contacts ) while the door close limit is active.
So u have a door issue. Lube clutch ramp. Check for binding.
Jluff #21564 09/08/17 10:00 PM
And clean or replace door lock contacts. Especially if they're ECI!
Indirtwetrust #21567 09/08/17 10:22 PM
Thanks, will do first thing Monday
Jcjphoenix #22114 11/04/17 03:09 PM
It turned out to be cold solder joints at the s door relay coil
PHP: 8.3.33 Page Time: 0.026s Queries: 24 (0.004s) Memory: 3.0152 MB (Peak: 3.5925 MB) Data Comp: Off Server Time: 2026-09-20 19:20:16 UTC
