93 Cobra Mustang
93 Cobra Mustang
Posts: 12 |
Hello to all my hard working fellow technicians.
KCM831 error 0169 Please help? I'm assuming back-up batteries? Unable to locate the UPS. Look forward to someones response.
Respectfully,
93 Cobra Mustang
93 Cobra Mustang
Posts: 12 |
It runs fine from inside the car but will not respond to hall calls.
Posts: 778 |
0169- The main line supply has been off to long or battery itself is broken The automatic battery test has detected low battery
Posts: 318 |
Replace the battery and start a 3 year cycle. Battery is in the cartop unit
Posts: 1,769 Likes: 12
Posts: 1,769 Likes: 12 |
You can set menu 5 parameter 14 to 22 to disable the battery supervision for 22 hours until you get a new battery.
Posts: 642 Likes: 5
Posts: 642 Likes: 5 |
Yeah, and when you open that car top box and ask yourself, " How the hell do I get that battery out of there?", simply loosen the two top phillips screws on the side ends of the box that support the battery and it folds down for easy access.
93 Cobra Mustang
93 Cobra Mustang
Posts: 12 |
Yep, that was definitely a problem. The battery is bulging and actually charging @ 14VDC. We'll get it replaced and turn down the pot and hopefully that's it. Thanks for all your help.
Respectfully,
Elevator Guy
Elevator Guy
Posts: 22 |
The side of the car top box with the battery Slides out. Loosen the battery holder screws Then 2 on each side of the box at the top And that side of the box will fold down. Unless someone put a stop switch or something else In the way hope this helps
