0 members (), 14 guests, and 2 robots.
#22005 10/25/17 08:23 PM
Kindly i have kone elevator with kdl32 drive giving fault 0007 ,(pin 30 stuck) lift stop at level and keep doors open , after rest it work and this fault comes 2 to 3 times per a day and some times work wor a month no fault , i change the pin 30 many times , i changed top of car board +ADO+ LCECPU to test and still have same problem , any one pass in this before ?
I have had this one before - Check the distance between 61U and 61N inductors and magnet on the floor that you are having the issue. Alternatively, replace 61U and 61N inductors[pins] one of them is faulty!
i am facing issue in kone elevator that lift start and goes downward in rated speed after 5 sec. and lift stop at next floor on maintenance speed error code occur 0152. kindly help me.
Check 77U, 77N, 77S inductors.
PHP: 8.3.36 Page Time: 0.037s Queries: 22 (0.009s) Memory: 3.0099 MB (Peak: 3.5904 MB) Data Comp: Off Server Time: 2026-11-05 13:24:52 UTC
