1 members (Zhivko_v), 72 guests, and 1 robot.
#22045 10/30/17 10:05 PM
BSP
BSP
33OA . Says on inspection . But all my inspection switches on car top, in car station and in machine room ring out ok and are in the run position. Changed CRIP board, changed CIOACD 3.Q. Checked I/O'S under status JREC (car top, Inactive = OK), (JRECC ,in car inspection inactive = ok) Drained GCIO 360 Capacitor 15 min, to .0070 vdc.
AND GO.......
THANKS
MBKE
I wonder if it would change if you disconnect the wires at the cpu?
Replace GCIO
On some equipment, car door/hall door bypass switch if turned on when the car is on auto will issue an INSP command. Confusing as heck if you're not ready for it.
BSP
BSP
CHANGED ALL INSPECTION KEY SWITCHES AND CAR TOP INSPECTION ROCKER. STILL NOTHING.... ORDERED NEW SOFTWARE 3.61
WE WILL SEE...
MBKE
BSP
BSP
SOFTWARE CHANGE DID NOTHING. SAYING AT 3RD FLOOR.REALLY AT BASEMENT. ALL IN NORMAL POSITION. SAYS ON INS. 121X 6E FAULT. NEW SWITCH INSTALLED. STILL NOTHING...
MBKE
BSP
BSP
SAYS MISMATCH ON CAR TOP INSPECTION SWITCH . NEW SWITCH AND THE FAULT STILL IS THERE
MBKE
Dumbguy=more$$$$
Dumbguy=more$$$$
Replace GC10
O
O Offline
Replace CIO board inside the COP with the same version.
GCIO
BSP
BSP
Thanks guys , I found a broken wire on the CIOACD . All better. !
MBKE
PHP: 8.3.36 Page Time: 0.029s Queries: 38 (0.008s) Memory: 3.0511 MB (Peak: 3.5927 MB) Data Comp: Off Server Time: 2026-11-04 22:15:40 UTC
