Page 1 of 2 1 2
#22266 11/27/17 03:34 PM
Hey everyone,
When lift goes downward direction left brake apply late whereas lift goes upward direction right brake apply late.
May anyone guide me ??
Azhar hussain #22273 11/27/17 07:30 PM
Sorry I am in USA. One brake is used for Emergency Brake and does not normally drop until goes to sleep. Other Brake picks and drops with runs. Make sure you do not have a magnetic residual issue (Metal touching that shouldn't).
Azhar hussain #22299 11/29/17 06:53 PM
Hey Rolly,
thank you, your advised but there is no any magnetic residual. will you advice any thing else?
Azhar hussain #22302 11/29/17 09:50 PM
Check the Parameters. What version of software you have and which CPU, 561 or 40?
Azhar hussain #22308 11/30/17 04:28 AM
Hey roll,
Software version is 3.19
CPU 40. Kindly advise me
Azhar hussain #22309 11/30/17 05:07 PM
OMG 3.19 is soooo old you could have many problems if that is in the cpu. Need at least 6.7.25 What country are you in?
Azhar hussain #22321 12/01/17 03:28 PM
Hahaha, yes this is very old version in Pakistan but kindly advise me solution
Azhar hussain #22322 12/01/17 11:22 PM
Upgrade all lifts software..
Azhar hussain #22331 12/02/17 05:36 PM
how it can be?
Azhar hussain #22358 12/06/17 01:34 AM
Rolly
I think he’s talking about the KDL16s software 3.19 which is fairly new. On the other hand,
CPU SOFTWARE under 6.7.25 won’t work with KDL16s anyways.
He’s probably referring to menu 6-97 which refers to drive software.
At least I hope he is lol
Azhar hussain #22359 12/06/17 01:36 AM
What’s parameter 5-9-?
Azhar hussain #22360 12/06/17 02:06 AM
Could be, don't even know what country he is in.
Azhar hussain #22543 12/20/17 04:41 AM
Dear everyone,
i hope, you all are happy. lift is not floor level on EBD but when lift is on floor level then door will open. fault occurs 0105, 0213. kindly advice me what can be happen.
Azhar hussain #22545 12/20/17 06:08 PM
0105 is power supply problem and or braking resistor broken and fault 0213 is no floor nodes found (probably linked to power supply problems).
Azhar hussain #22565 12/23/17 05:06 AM
Dear all who have a idea for kone MX 18 model . We can’t start generator power because error 213 showed.
Azhar hussain #22566 12/23/17 06:12 PM
Newly joined how can I ask questions embarrassing to admit this new tech is a challenge
koneisland #22567 12/23/17 06:13 PM
Azhar hussain #22568 12/23/17 06:15 PM
Just joined how can i post a question is there a icon or title so I can ask questions
davidneel #22571 12/23/17 07:25 PM
hi davidneel,
check shaft network power supply or XM13 connector.
Azhar hussain #22580 12/24/17 12:13 PM
Thank you I will check
Page 1 of 2 1 2
PHP: 8.3.36 Page Time: 0.055s Queries: 55 (0.022s) Memory: 3.1123 MB (Peak: 3.5923 MB) Data Comp: Off Server Time: 2026-11-06 05:10:00 UTC
